Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge > Process of Meeting the Requirements for an Incremental Upgrade to Siebel CRM Version 15.5 or Later, Using the Incremental Repository Merge > Preparing Siebel Tools for Custom ODBC Data Source Names on Oracle DatabasePlatforms: Windows, UNIX, and IBM z/OS. Use this task if you have a custom ODBC data source on Oracle Database. This task is a step in Process of Meeting the Requirements for an Incremental Upgrade to Siebel CRM Version 15.5 or Later, Using the Incremental Repository Merge. If you create a custom ODBC data source name for Oracle Database instead of using the default ODBC data source name, then you must perform the following modifications to enable Siebel Tools for the incremental repository merge. After Siebel Tools is installed, the ODBC data source named SSD default instance is automatically set up by the configurations, using the Oracle driver installed by the installation. To prepare Siebel Tools for a custom data source name on Oracle Database
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
