Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge > Process of Meeting the Requirements for an Incremental Upgrade to Siebel CRM Version 15.5 or Later, Using the Incremental Repository Merge > Preparing Siebel Tools for Custom ODBC Data Source Names for All DatabasesThis task is a step in Process of Meeting the Requirements for an Incremental Upgrade to Siebel CRM Version 15.5 or Later, Using the Incremental Repository Merge. If you create a custom ODBC data source name instead of using the default ODBC data source name, then you must perform the following modifications to enable Siebel Tools for the incremental repository merge. To prepare Siebel Tools for a custom ODBC data source name for all databases |
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
