Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge > Process of Regenerating the Siebel Repository Definition FilesThe tasks in this process enable you to regenerate the Siebel Repository definition files. Environments: Development environment only. If you have modified repository objects after the development environment upgrade (upgphys) and before upgrading the production test environment, then you must regenerate the schema.ddl and custrep.dat files. These files were created during the development environment upgrade (upgphys):
These files are used as input to the production test and production environment upgrades. If you modify the object definitions or the schema definitions in the repository after these files have been created, then you must regenerate the files. Perform the following tasks to regenerate the Siebel Repository definition files: |
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
