Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge > Process of Regenerating the Siebel Repository Definition Files >
Editing the Siebel Tools Configuration File After the Development Environment Merge
This task is a step in Process of Regenerating the Siebel Repository Definition Files. Use this task to edit the Siebel Tools configuration file after successfully performing your Development environment repository merge. CAUTION: You must set the prefix to back to X_ from changed value of SBL_ to enable you, after the merge, to create your own custom symbolic strings.
To change the SymStrPrefix value in tools.cfg file
- Navigate to
SIEBEL_TOOLS_ROOT\bin\lang_code, and open the tools.cfg file.
- Make the following changes in the tools.cfg file:
- Change the SymStrPrefix value from SBL_ back to the default value of X_.
- Make sure the Set EnableToolsConstrain value is set to the default value of False. If it is not, then set the value to False.
- Change the DockRepositoryName value from Prior Customer Repository to Siebel Repository.
- Save the tools.cfg file.
