Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge > Performing a Production Test or Production Environment Migration from Siebel CRM Version 8.1.1.x (SIA Repository)Environments: Production test and production. To upgrade your production environment use the following task. For information on Siebel Database Configuration Wizard parameters, see Preparing to Run the Siebel Database Configuration Wizard. For information on running the Database Configuration Wizard, see Running the Siebel Database Configuration Wizard on Windows or Running the Siebel Database Configuration Wizard on UNIX, depending on your platform. Requirements: You must copy the schema.ddl and the custrep.dat files to your production test environment and production environment to conduct upgrades in each of these environments. For more information, see Process of Regenerating the Siebel Repository Definition Files. To perform a production upgrade
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
