Siebel Database Upgrade Guide > Siebel Postmerge Development Tasks > Reviewing Objects Deleted from the Siebel RepositoryEnvironments: Development environment only. Platforms: Windows, UNIX, IBM z/OS. If an object you have deleted from the Prior Customer Repository exists in the New Customer Repository, then the repository merge does not delete the object from the New Customer Repository. After the merge, you must review these objects and verify that they do not adversely affect the operation of the application. Requirements: The repository merge must have been successful. See Reviewing the Siebel Repository Merge Log Files. To generate a list of deleted objects
Related Topics |
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
