Siebel Database Upgrade Guide > Siebel Postmerge Development Tasks > Reviewing Obsolete Objects in the Siebel RepositoryEnvironments: Development environment only. Platforms: Windows, UNIX, IBM z/OS. Objects that were available in the Prior Siebel Repository but are not available in the New Siebel Repository are obsolete. After performing the repository merge, you can generate a list of obsolete objects using Siebel Tools. Objects that were available in the Prior Siebel Repository are compared with the objects that are available in the New Siebel Repository. Requirement: The repository merge must have been successful. See Reviewing the Siebel Repository Merge Log Files. To generate a list of obsolete objects
Related Topics |
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
