Siebel Database Upgrade Guide > Reviewing the Siebel User Interface > Eliminating Obsolete Siebel UI FieldsUpgrades from: All Supported Siebel releases. This topic applies only to upgrades using the Incorporate Custom Layout (ICL) feature. For more information, see Siebel Incorporate Custom Layout Upgrade Option. Environments: Development environment only. Platforms: Windows, UNIX, IBM z/OS. Reputility log section: "Issue 7: Fields deprecated from Business Components." Some of the business component fields in your installed release might be obsolete in the new release. If you have customized existing applets or created new ones, and you selected ICL during the merge, then the UI might contain obsolete fields or controls. If a business component field is not available for an applet field or control after the merge, then the field or control does not display. The reputility log lists the applets that contain obsolete business component fields. Review the section of the log referenced above and revise applet definitions and layouts as required.
Related Topics |
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
