Siebel Database Upgrade Guide > Reviewing the Siebel User Interface > Setting Up Navigation to Inaccessible Siebel Detail ViewsEnvironments: Development environment only. Platforms: Windows, UNIX, IBM z/OS. Reputility log section: "Issue 6: Categories Where Parent Applets Are Missing Drilldowns to a Detail View." The postmerge utilities verify that you can navigate from a screen to all the screen detail views listed in the parent category for the screen. If any of the screen's detail views are not accessible using normal navigation methods, then the utilities list the screen name, parent category, and the Aggregate View in the log. In many cases, the problem is caused by a missing or incorrectly defined drilldown in a list applet in the view shown in the log. The missing drilldown prevents the user from navigating to a view containing third-level view tabs that provide access to all the detail views. Review the section of the log referenced above and make needed revisions.
To set up navigation to inaccessible detail views
Related Topics |
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
