Siebel Database Upgrade Guide > Reviewing the Siebel User Interface > Assigning a Category and Type to Siebel Explorer ViewsEnvironments: Development environment only. Platforms: Windows, UNIX, IBM z/OS. Reputility log section: "Issue 5: Explorer Views Needing Migration to Aggregate Type." NOTE: This topic does not apply to 7.x upgrades that used the Incorporate Custom Layout (ICL) feature. The postmerge utilities review the repository and verify that explorer views are defined correctly. The reputility.log, lists the explorer views that require revision. Review the section of the log referenced above and make the needed revisions.
Assigning a New Web Template to a ViewUse the following procedure to assign a new Web template to a view. To assign a new Web template to a view
Assigning a New Type to a Screen ViewUse the following procedure to assign a new type to a screen view. To assign a new type to a screen view
Related Topics |
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
