Siebel Database Upgrade Guide > Reviewing the Siebel User Interface > Assigning a Category and Type to Siebel Chart ViewsEnvironments: Development environment only. Platforms: Windows, UNIX, IBM z/OS. Reputility log section: "Issue 4: Chart Views Needing Migration to Aggregate Type." The Chart menu item displays as one of the aggregate categories under the view tabs. To ensure that the Chart menu item is located correctly, all the relevant charts for a view must be assigned to the same Aggregate Category. Also, each chart view must be of type Aggregate View. If the chart view is not of type Aggregate View, then the chart menu item displays as a view tab. The postmerge utilities review the repository and verify that Chart views have been defined correctly. The reputility log lists the screen views that require revision. Review the section of the log referenced above and make the needed revisions.
To assign a category and type to chart views
Related Topics |
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
