Siebel Database Upgrade Guide > Postupgrade Tasks for the Siebel Database >
Validating Dock Objects and Rule Definitions in the Siebel Database
Environments: Development, production test, production. Platforms: Windows, UNIX, IBM z/OS. Changes to visibility rules and dock objects require the assistance of Oracle Advanced Customer Services. If you deploy Siebel Business Applications to mobile users with local databases, then you can run the DICTUTL utility to verify that all dock objects and rule definitions are correct. Dock objects allow mobile users to synchronize their local databases with the Siebel Server. Rules determine which data users synchronize. For more information about dock objects and rules, see Siebel Tools Online Help and Siebel Remote and Replication Manager Administration Guide. To verify that all dock object and rule definitions are correct
- Navigate to the following directory:
Windows: SIEBEL_ROOT \bin
UNIX: $SIEBEL_ROOT /bin
- Type the following command using the parameters specified in
Table 37:
dictutl /C ODBC_DATASOURCE /U USERNAME /P PASSWORD /D TABLEOWNER /N "REPOSITORY_NAME " /A y 2> logfile.log
Table 37. Command Line Flags for DICTUTL
/C |
ODBC_DATASOURCE
ODBC datasource name |
Yes |
/U |
USERNAME
User name to log in to database |
Yes |
/P |
PASSWORD
User password to log in to database |
Yes |
/D |
TABLEOWNER
User name of tableowner |
Yes |
/N |
"REPOSITORY_NAME " |
Name of repository for dictionary (the parameter must be bounded within double quotes) |
Yes |
/A |
y or n
Enter the y parameter to ignore the dictionary cache. Enter n if you do not want to ignore the dictionary cache. |
Yes |
- Review the
LOGFILE .log file:
- Open the file in Microsoft Excel. If the file is too large for Excel to display the whole file, then break the file into two files and examine each separately.
- Query for the word error.
- If you locate errors, then write down the exact error text.
- Query for the word syntax.
- If you locate syntax errors, then write down the exact error text.
- To determine whether the errors must be resolved, contact your Oracle sales representative for Oracle Advanced Customer Services to request assistance from Oracle's Application Expert Services.
The following types of entries indicate that no errors were found:
Related Topics
Preserving Siebel Dock Objects and Visibility Rules
