Siebel Database Upgrade Guide > Preparing for Siebel Database Upgrade > Exporting Siebel Interface Table DataEnvironments: Development, production test, production. Platforms: Windows, UNIX, IBM z/OS. During the upgrade process, your interface tables are dropped and then re-created. To retain data in your interface tables, use the appropriate tools for your RDBMS to export data before the upgrade and then import the data after you have completed the upgrade. During the upgrade, all custom indexes on interface tables are dropped from both logical and physical schema. |
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
