Siebel Database Upgrade Guide > Preparing for Siebel Database Upgrade > Archiving Unneeded Siebel RepositoriesEnvironments: Development, production test, production. Perform this task before running the Database Configuration Utilities in upgrep mode for the first time in an environment. The upgrep mode scripts expect only the Siebel Repository to be present. If you have multiple repositories, then you must export them to archive files and then delete them from the database. Because the upgrade changes the schema of the database, in most cases you cannot import these archived repositories into the upgraded database. If you want to access the archived repositories, then you must import them into a database that has the same schema as the one from which they were exported. |
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
