Siebel Database Upgrade Guide > Preparing for Siebel Database Upgrade > Securing AIX Memory Allocation Segment Space for the Siebel DatabaseEnvironments: Development, production test, production. Databases: All databases. (Exception: this topic does not apply to Microsoft SQL Server.) Before you run an upgrade on AIX, set the following environment variable on the AIX computer that you are using for the upgrade:
This will prevent a shortage of memory allocation segment space that might occur on the computer where both the Siebel Database Server and Siebel Server are installed. After a successful upgrade, reset this parameter to the original value. |
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
