Siebel Database Upgrade Guide > Preparing for Siebel Database Upgrade > Preparing for a Multilingual UpgradeEnvironments: Development, production test, production. Platforms: Windows, UNIX, IBM z/OS. As of Siebel CRM 8.0, the upgrade process upgrades both the primary (base) language and all deployed languages. The Database Configuration Utilities validate deployed languages by comparing the status of the language packs installed on the Siebel File System with the language IDs of records in the S_LST_OF_VAL table. If there are language IDs in S_LST_OF_VAL but no corresponding deployed language on the Siebel File System, then the validation fails and you cannot continue the upgrade. Before doing an upgrep, use Siebel Tools to remove or deactivate any records in S_LST_OF_VAL for undeployed languages. To prepare for a multilingual upgrade
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
