Siebel Database Upgrade Guide > Preparing an IBM DB2 Database for a Siebel Upgrade > Verifying IBM DB2 Sort Order for a Siebel UpgradeEnvironments: Development, production test, production. Binary sort order is required for the development environment upgrade and is strongly recommended for the production environment upgrades. Sort order is specified during creation of the database. If you find that your IBM DB2 development database was not created using Identity sort order, then you must re-create your database using the option If sort order is correct, but you are still encountering errors, contact your Oracle sales representative for Oracle Advanced Customer Services to request assistance from Oracle's Application Expert Services to help in further analysis. To verify that your database was created using Identity sort order |
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
