Siebel Database Upgrade Guide > Preparing an IBM DB2 Database for a Siebel Upgrade >
Setting IBM DB2 Parameters for a Siebel Upgrade
Environments: Development, production test, production.
Databases: IBM DB2 only.
Before upgrading an IBM DB2 database, verify that your database server meets or exceeds the following configuration criteria:
  • The DMS tablespace has at least 25% of free pages.
  • The file system has sufficient space to allow your DMS tablespace to grow.
  • Siebel tablespaces for IBM DB2 must be database-managed tablespaces (DMS) rather than system-managed tablespaces (SMS).
  • Verify that the tablespaces are not near their capacity. This can be done by connecting to the database and issuing the following command:
    DB2 list tablespaces show detail
The tables which follow provide upgrade-specific settings for the Database Manager and database. Use the following strategy to set parameters:
  • Set parameters using the recommendations in Siebel Installation Guide for the operating system you are using. Recommendations are located in the chapter on configuring the RDBMS.
  • For the upgrade, revise the configuration parameters listed in the tables which follow.
  • After the upgrade, reset the configuration parameters to the values listed in Siebel Installation Guide for the operating system you are using.
IBM DB2 Database Manager Settings
The Upgrade Setting column in Table 17 provides guidelines for setting configuration parameters specifically to optimize upgrade performance. Set these parameters for each IBM DB2 instance.
Table 17. IBM DB2 Database Manager Configuration Parameters
Parameter
Explanation
Upgrade Setting
SHEAPTHRES
Sort heap threshold (4 KB)
If you reset SHEAPTHRES or SORTHEAP, then rebinding the instance is recommended.
Double the value allocated for SORTHEAP. See Table 18.
IBM DB2 Database Configuration Parameters
The Upgrade Setting column in Table 18 provides guidelines for setting configuration parameters specifically to optimize upgrade performance. Set these parameters for each IBM DB2 instance.
Table 18. IBM DB2 Database Configuration Parameters
Parameter
Explanation
Upgrade Setting
SORTHEAP
Sort list heap (4 KB)
20000—40000 Recommended size; this might increase or decrease depending on the amount of memory in the database server computer and the size of the data.
A 20000 setting allows SORTHEAP to increase up to 80 MB.
MAXLOCKS
Percentage of lock lists for each application
5
CHNGPGS_THRESH
Changed pages threshold
5
LOGRETAIN
Sequential or circular log files
NO
Setting this parameter to YES means that log files are archived. You must periodically move or archive the log files to prevent the file system containing the log files from filling up.
LOGFILSIZ
Log file size (4 KB)
Development environments:
8000-16000
SOFTMAX
Triggers bufferpool flushing
50
Siebel Database Upgrade Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
