Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide > Customizing the Integration >
Installing the Oracle AIA Foundation Pack Enterprise Object Library
This topic describes how to copy the Enterprise Object Library from the Oracle AIA Foundation Pack to obtain the EBOs, EBSs and EBMs required for your customization. This task is a step in Process of Customizing the Integration. To install the Oracle AIA Foundation Pack Enterprise Object Library
- Download the Oracle AIA Foundation Pack 11g Release 1 to your local computer from Oracle Software Delivery Cloud at
http://edelivery.oracle.com
- Install the Oracle AIA Foundation Pack as described in Oracle® Fusion Middleware Installation and Upgrade Guide for Oracle Application Integration Architecture Foundation Pack 11g Release 1 (11.1.1.4.0).
- After the installation, verify that the Oracle AIA Foundation Pack directory structure is as follows on your local computer:
- EBOs and EBMs are located as follows:
AIA_HOME\AIAMetaData\AIAComponents\EnterpriseObjectLibrary\Industry\BankingAndWealthManagement\EBO\Entity\
- Enterprise Business Service WSDL XML documents are located as follows:
AIA_HOME\AIAMetaData\AIAComponents\EnterpriseBusinessServiceLibrary\Industry\BankingAndWealthManagement\EBO\Entity\
where:
AIA_HOME is the Oracle AIA Foundation Pack installation directory
Entity is the name of the entity, for example, Loan Account, required for the customization
