Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide > Troubleshooting the Integration >
Siebel Log Files During Batch Data Loading
This topic provides information on the Siebel log files generated during batch data loading using Oracle Data Integrator. After performing the batch data loading, check the following log files for errors:
- Log table BIB_ODI_ERROR_LOG
If an error occurs while running the packages for the batch data loads, then the error message is logged in the table BIB_ODI_ERROR_LOG in the Siebel database. This table stores the following information about the error:
- Package name
- Step name
- Step type
- Error code
- Error message
- Created date
- EIM log files
During the batch data loading, Oracle Data Integrator loads data from Oracle FLEXCUBE Universal Banking staging tables into Siebel EIM tables. Oracle Data Integrator starts the Siebel EIM jobs, using the Siebel Server Manager utility. If an error occurs in a Siebel EIM job, then a log file is created in the location you specified for the variable FINS_BIB_Log_Path. For additional information, see Configuring Integration Variables.
Check the log files for any errors during the Siebel EIM job processing.
