Siebel Database Upgrade Guide for DB2 for z/OS > How the Siebel Database Upgrade Works >
Supported Upgrade Paths for Siebel Innovation Pack 2015, Patchset 5 or Later
Table 3 lists supported upgrade paths for Siebel Innovation Pack 2015, Patchset 5 or later (SIA repository) on the IBM DB2 for z/OS database platform. NOTE: After installing the Siebel CRM software for the current release, you must reset any passwords in the siebns.dat file on the Siebel Gateway Name Server that were previously encrypted using RC4 encryption. In the current release, such passwords are encrypted using Advanced Encryption Standard (AES) instead of RC4. You must perform this task regardless of the type of upgrade you are performing. For more information about reencrypting passwords, see Siebel Security Guide.
Table 3. Supported Upgrade Paths for Siebel Innovation Pack 2015, Patchset 5 or later on IBM DB2 for z/OS
Siebel 7.5.3 (SEA repository or SIA repository) and Siebel 7.7.2 (SEA repository or SIA repository) |
- New installation of Siebel Innovation Pack 2015 (version 15.0) for upgrade.
- Installation of Siebel Patchset 5 or later.
- Full database upgrade.
- Two-step repository upgrade.
You must perform a two-step repository upgrade:
- Upgrade Siebel CRM version 7.5.3 and Siebel CRM version 7.7.2 (SEA repository or SIA repository) to Siebel CRM version 8.1.1 (SEA repository or SIA repository).
- Upgrade Siebel CRM version 8.1.1 (SEA repository or SIA repository) to Siebel Innovation Pack 2015, Patchset 5 or later (SIA repository).
NOTE: Use incremental repository merge for upgrades from Siebel CRM version 8.1.1 (SIA repository).
Siebel 7.8.2 (SIA repository and SEA repository) Siebel 8.0 (SIA repository and SEA repository) Siebel 8.1.1.0 (SEA repository) |
- Single-step upgrade.
- Perform a full database upgrade. A Development environment upgrade and a Production environment upgrade is required.
- You can directly upgrade to Siebel Innovation Pack 2015, Patchset 5 or later. It is a single-step upgrade and post-upgrade process.
- The New Customer repository, generated through a three-way repository merge, contains all the content from the Siebel Innovation Pack 2015, Patchset 5 or later. For more information on repository merge, see Performing the Siebel Repository Merge.
Siebel 8.1.1.0 through 8.1.1.14 (SIA repository) |
- Migration installation of Siebel Innovation Pack 2015 (version 15.0).
- Incremental repository merge.
- Run Oracle Universal Installer (OUI) to apply the Siebel Innovation Pack 2015, Patchset 5 or later SIA patch release.
NOTE: Siebel Innovation Pack content is not included in the patch release.
- If you intend to use new features included from the Siebel Innovation Pack 2015, Patchset 5 or later, then you must import the Innovation Pack using incremental repository merge. For more information on incremental repository merge, see Performing the Siebel Incremental Repository Merge.
Siebel CRM version 15.0 |
- Installation of Siebel Innovation Pack 2015, Patchset 5 or later.
- (Optional) incremental repository merge.
- Use incremental repository merge to bring the repository to Siebel Innovation Pack 2015, Patchset 5 or later.
NOTE: Running incremental repository merge is optional if you previously ran it for version 15.0 or performed a new installation of version 15.0. However, you must run incremental repository merge to be able to use new features of Siebel Innovation Pack 2015, Patchset 5 or later.
