Using Siebel Tools > Reference Materials for Siebel Tools > Menus and Menu Items on the Menu Bar >
Help Menu
Table 29 describes the menu items that you can click from the Help menu.
Table 29. Menu Items That You Can Click from the Help Menu
Menu Item
Description
Contents
Opens the Siebel Tools Online Help.
Using Help
Technical Support
Displays the Technical Support Information dialog box that includes information that Technical Support might require, such as the version number of your Siebel Tools installation.
About Record
Opens a dialog box that displays information about the current object, including the object creator and creation date.
About SRF
Opens a dialog box that displays information about the most recent full incremental compile.
About View
Opens a dialog box that displays information about the current screen, business object, and view, including applet layout.
About Visible Views
Displays the list of views in the repository and if each view is visible. Visibility for each view depends on the license key you use when you install Siebel Tools. For more information, see Description of the About Visible Views Dialog Box.
About Siebel Tools
Opens a dialog box that identifies the version of Siebel Tools.
Table 30 describes the information that the About Visible Views dialog box shows. To view this dialog box, you click the Help menu and then click About Visible Views.
Table 30. Description of the About Visible Views Dialog Box
Column
Description
View Name
Displays the view name. The views in this column are not the predefined views in Siebel Tools.
Visible
Shows whether or not the view is visible in Siebel Tools.
Application
Shows whether or not the view is associated with Siebel Tools.
View
Shows whether or not the view always appears as a view in Siebel Tools.
Responsibility
Shows whether or not the view is associated with user responsibilities.
License
Shows whether or not the view visibility depends on the license key that you use when you install Siebel Tools.
Platform
Shows whether or not the view visibility depends on the platform that Siebel Tools uses.
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
