Using Siebel Tools > Archiving Objects > Importing Objects from an Archive > Using the Command Line to Import an ArchiveYou can use the command line to import objects from an archive. You can also use the command line to do other work. For more information, see Using the Command Line to Import, Export, or Compile Objects. To use the command line to import an archive
Example of Using the Command Line to Import an ArchiveThe following example imports an archive: siebdev.exe /c tools.cfg /d sample /u sadmin /p sadmin /batchimport "siebel repository" overwrite ..\import1.sif "C:\Program Files\Siebel\8.0\Tools\import2.sif" import.log This command imports the following files:
It uses the overwrite option for conflict resolution. It logs the results to the import.log file. For more information, see Options You Can Choose to Resolve a Conflict. Example of Importing All FilesThe following example imports all files: siebdev.exe /c tools.cfg /d sample /u sadmin /p sadmin /batchimport "siebel repository" merge "C:\Program Files\Siebel\8.0\Tools\importfiledir" import.log This command imports all files in the following folder:
It uses the merge option for conflict resolution. It logs the results to the import.log file. |
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
