Using Siebel Tools > Archiving Objects > Importing Objects from an Archive > Preparing the Siebel Tools Environment to Import Objects from an ArchiveYou must prepare the Siebel Tools environment before you import an archive. To prepare the Siebel Tools environment to import objects from an archive
Checking Out and Locking Projects Before You Import an ArchiveEach object in an archive references a project. You must make sure that you check out and lock each of these projects. You can import an archive only to a project that is checked out in the local database of a client computer. Do not import to the Server database. The only exception includes projects or objects that reside in the archive but that do not exist in the repository. These projects are not checked out because they do not exist in the repository. In some situations it might be difficult to identify the projects you must check out. The Import wizard informs you of any unlocked projects that you must lock. It does this after it analyzes the objects in the archive and compares them to the objects that reside in the repository. For more information, see Using Checkout and Checkin. |
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
