Using Siebel Tools > Managing Repositories > Viewing, Renaming, Comparing, and Configuring Repositories >
Viewing Information About the Current Repository
Only one repository is available to your local database, and only one repository is available to the server database for your development workgroup. If you log in to Siebel Tools, and if you connect to the local database or the server database, then Siebel Tools opens this repository, by default. In some situations, multiple repositories might reside on the Siebel Server (for example, if you upgrade to a new version of Siebel CRM). To view information about the current repository
- In Siebel Tools, click the File menu, and then click Open Repository.
Siebel Tools displays the Open Repository dialog box. This dialog box lists the repositories in the database that Siebel Tools uses. Siebel Tools highlights the repository that it is currently using.
- Click the Help menu, and then click About SRF.
- Examine the information that the About Repository File dialog box shows using the information from the following table.
Internal Version |
Version number that Oracle maintains. Siebel CRM modifies this value only if the internal format of the repository is modified (for example, during an upgrade). |
User Version |
Reserved for use by Oracle's Siebel Anywhere. It maintains this number when Oracle creates kits that upgrade the repository. Siebel CRM reads this value when it does a version check. |
Full Compile |
Choose this option to display information about the most recent full compile. |
Last Incremental Compile |
Choose this option to display information about the most recent incremental compile. If no incremental compile has occurred since the last full compile, then this option is not available. |
When |
Date of the last compile. |
Machine Name |
Name of the computer that Siebel CRM uses to compile the repository. |
Language |
Language code. |
User Name |
The Microsoft Windows logon name of the user who compiled the repository. |
Repository |
Repository name of the repository that was current when Siebel CRM performed the compile. This value is typically Siebel Repository. |
Tools Version |
The version number and build number of the Siebel Tools software that performed the compile. Global Customer Support can use this information to help you resolve a problem. |
Schema Version |
Database schema version of the Siebel database that Siebel CRM uses to compile the repository. |
File Name |
File name and path of the repository that Siebel Tools is currently using. The default folder is SIEBEL_TOOLS_ROOT \OBJECTS . |
