Using Siebel Tools > Managing Repositories > Viewing, Renaming, Comparing, and Configuring Repositories > How Siebel Tools Minimizes Processed Data During Exports and ImportsYou can use Siebel Tools to create a Siebel Delta File (SDF), which is a type of file that is similar to an SIF file except that an SIF file contains the entire definition of an object, while the SDF file contains only information about modifications to an object. The SDF file contains enough information about the object hierarchy so that it can get the modified information. For example, you use Siebel Tools to modify the contents of a comment field in the Contact business component. In this example, you use one of the following file types to move this modification from a source environment to a destination environment:
Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
