Using Siebel Tools > Archiving Objects > Using the Application Deployment ManagerThe Application Deployment Manager (ADM) is a feature that you can use to administer a Siebel CRM deployment. Siebel Tools supports ADM through the following business service: Siebel Tools Export Support for ADM It allows you to export individual objects to a hotfix or to export all objects that Siebel CRM modified after a particular date and time to a mid-level release. For more information, see Siebel Application Deployment Manager Guide. |
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
