Using Siebel Tools > Archiving Objects > Importing Objects from an Archive > Using the Review Conflicts and Actions Dialog Box of the Import WizardFigure 7 includes the dialog box that appears if Siebel Tools determines that a difference exists between an object in the repository and an object in the archive. You can use this dialog box to review differences and to modify the work that Siebel Tools does to resolve the conflict. Conflicting Objects SectionThe Conflicting Objects section displays the hierarchy of objects that include differences. This hierarchy uses the same structure as the object type hierarchy in the repository but it displays only objects that include conflicts rather than all repository objects. The objects in the Object Differences dialog box include objects for all hierarchical levels, not just top-level objects. Object Differences SectionThe Object Differences section lists the objects that include a difference. It includes the following columns:
Attribute Differences SectionThe Attribute Differences section displays the property value conflicts for the object you choose in the Object Differences section. It lists only the properties that include a conflict. Siebel CRM uses the terms attribute and property. These terms have the same meaning. Table 19 describes the columns in the Attribute Differences section. |
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
