Using Siebel Tools > Archiving Objects > Overview of Archiving ObjectsArchiving is a process where you export objects from the repository to an archive file. You can then import objects from the archive file back into the repository. You can use an archive to back up sets of objects or move them to another environment that shares the same physical database schema as the source environment. Note the following:
For more information about the files that you use when archiving objects, see Files That You Use to Manage Repositories. Using Export and Import for Different Versions of Siebel CRMIf you export objects from one version of Siebel CRM to another version, then do not import these objects through .sif files into a different version of Siebel CRM because Siebel CRM might modify object definitions between these versions. If you import an object that is not valid, then an invalid configuration might result. Oracle does not support an invalid configuration. Where Siebel Tools Stores Archive FilesThe Temp parameter in the Siebel section of the tools.cfg file identifies the folder where Siebel Tools stores the following items: Siebel Tools sets this Temp parameter to the |
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
