Using Siebel Tools > Checking Out and Checking In Projects and Objects > Setting Options for Checkout and Checkin >
Configuring Third-Party Code Control
You can integrate the checkin feature in Siebel Tools with a code control system from a third party. You can use any third-party control system that Siebel CRM can start and control from a batch file. Some example third-party control systems include Borland Star Team, ClearCase, CVS Open Source, Microsoft Visual SourceSafe, Serena, and PVCS. If you use third-party code control, then Siebel Tools creates an archive each time you check a project into the server repository. It also checks the project into the code control system. The archive includes all the objects that the project contains. The code control system can include successive versions of this project. You can use third-party code control only to check in items. You cannot use it to check out items. For more information, see Archiving Objects. To configure third-party code control
- In Siebel Tools, click the View menu, and then click Options.
- In the Development Tools Options dialog box, click the Check In/Out tab.
- Set the options in the Source Control Integration section.
For more information, see Elements of the Check In Dialog Box.
- Click OK.
- Modify the batch file.
For more information, see Configuring the Predefined Batch File.
Using Checkin with Third-Party Code Control
After you configure Siebel Tools to use third-party code control, you can use Siebel Tools to check in projects just like you typically do. In this example, assume the following:
- Project A and Project B are currently checked out.
- You want to check these projects into the server repository and into the code control system.
- Version 5 is the latest version of the ProjectA.sif file in the code control system.
- Version 6 is the latest version of the ProjectB.sif file.
To use checkin with third-party code control
Reverting to a Prior Version
In this example, you revert version 5 of Project A that you checked into the server repository. You revert this version to version 4. To revert to a prior version
- Check out version 4 of the ProjectA.sif file from the code control system into the following folder:
SIEBEL_TOOLS_ROOT\TEMP
- Check out ProjectA from the server repository.
- Import the ProjectA.sif file into the local repository, and use the Overwrite option to resolve object definition conflicts.
This step replaces the existing version of ProjectA with the archived version.
- Check ProjectA into the server repository.
Siebel Tools checks the ProjectA.sif file into the code control system as version 6.
The srcctrl.bat batch file includes the commands that the code control software uses to check the archived projects into the code control system. You must modify this file, and then distribute it to your developers. The following command runs this batch file: SRCCTRL action folder comment_file project_file
where:
- action is
check in. You cannot use check out.
- folder is the folder that includes the items.
- comment_file is a file that includes comment text that Siebel Tools sends to the code control system with the project file.
- project_file is the name of the archive file for one project, enclosed in double quotes. For more information about archive files, see Overview of Archiving Objects.
You cannot modify this command. You cannot modify the parameters that it sends. After checkin finishes, Siebel Tools runs the srcctrl.bat file one time for each project. It checks the archive file for the project into or out of the code control system. For information, see Code of the Predefined Batch File and About Predefined Objects. Support for Using the Predefined Batch File
Oracle can help you troubleshoot source integration, but modifying the srcctrl.bat batch file is your responsibility. To get support on third-party commands that you place in this batch file, you must contact the vendor who provides the third-party source control system. Code of the Predefined Batch File
The following srcctrl.bat file comes predefined with Siebel CRM. You must modify this batch file so that it uses the path that your environment uses: set PATH=C:\Program Files\DevStudio\Vss\win32\;%PATH% set SOFTWARE=ss set CHECKIN=%SOFTWARE% checkin set CHECKOUT=%SOFTWARE% checkout set ADD=%SOFTWARE% add set SETPROJ=%SOFTWARE% cp set PROJECT=$/PROJPOOL set SRC_USR= set SRC_PSWD= set OPTIONS=-i-y -y%SRC_USR%,%SRC_PSWD% set COMMENT=-c@ set NON_COMMENT=-c- set FILE= set LOGFILE=C:\Temp\xml.log echo =======================srcctrl.bat========================== >> %LOGFILE% set ACTION=%1 shift set DIR=%1 shift set COMMENT=%COMMENT%%1 shift set FILE=%1 echo Change local folder to %DIR% >> %LOGFILE% chdir %DIR% >> %LOGFILE% 2>&1 echo Set %PROJECT% as the working folder at Code Control System >> %LOGFILE% %SETPROJ% %PROJECT% >> %LOGFILE% 2>&1 if errorlevel 100 goto END if %ACTION%==checkout goto CHECK_OUT if %ACTION%==checkin goto CHECK_IN :CHECK_OUT echo ============Check out file %FILE% from Code Control System============ if not exist %FILE% echo "New File" >> %FILE% attrib +r %FILE% echo Add %FILE% if it doesn't exist in Code Control System >> %LOGFILE% %ADD% %FILE% %NON_COMMENT% %OPTIONS% >> %LOGFILE% 2>&1 echo Start checking out %FILE% from Code Control System >> %LOGFILE% %CHECKOUT% %FILE% %NON_COMMENT% %OPTIONS% >> %LOGFILE% 2>&1 goto END :CHECK_IN echo ============Check in file %FILE% into Code Control System============ echo Check in %FILE% into Code Control System >> %LOGFILE% %CHECKIN% %FILE% %COMMENT% %OPTIONS% >> %LOGFILE% 2>&1 attrib -r %FILE% goto END :END echo ===================End Of srcctrl.bat====================== >> %LOGFILE%
Parameters That the Batch File Uses
Table 9 describes the parameters that the srcctrl.bat batch file uses.
Table 9. Parameters That the Batch File Uses for the Code Control Software
PATH |
Identifies the folder where you install the code control software. You must modify this parameter so that it identifies this folder. |
SOFTWARE |
Name of the command-line utility that the code control system uses. For example, Microsoft Visual SourceSafe uses the ss command-line utility. |
CHECKIN |
Requests checkin into the code control system. |
CHECKOUT |
Requests checkout from the code control system. |
ADD |
Requests to add files in the code control system. |
SETPROJ |
Sets the working folder in the code control system. |
PROJECT |
Identifies the working folder in the code control system that includes the items that this system checks in and checks out. |
COMMENT |
Text of the Comments clause that runs in the command line for each file that the code control system checks in or checks out. |
OPTIONS |
Text of the Options clause that runs in the command line. |
SRC_USR |
User name that the Options clause includes in the command line. This user name is the logon name for the code control system. It is not the user for a Siebel application. |
SRC_PSWD |
User password that the Options clause includes in the command line. This password is the password for the code control system. |
FILE |
Name of the archive file. The parameter list of the batch file includes this file name. You must check in or check out this file. |
LOGFILE |
Path and file name of the log file that the batch file creates. |
Running Simultaneous Siebel Tools Sessions After You Modify the ODBC Data Source
If you modify the ODBC data source, and then exit Siebel Tools, then Siebel Tools writes these modifications to the Siebel Preference Files (SPF) in the following folder: SIEBEL_TOOLS_ROOT\BIN
It caches these preferences. The next time you Log in to Siebel Tools, it does not read the ODBC settings in the tools.cfg file, and you cannot use a single user Id to run simultaneous Siebel Tools sessions. You can open only one local data source at a time. For more information, see Specifying the Data Source That Siebel Tools Uses and About the Configuration Files.
