Using Siebel Tools > Reference Materials for Siebel Tools > Dialog Boxes That Check Out and Check In Projects and Objects >
Elements of the Check In Dialog Box
Table 42 describes the elements of the Check In dialog box. For information about using this dialog box, see Checking In Projects or Objects to the Server Repository.
Table 42. Elements of the Check In Dialog Box
Element
Description
Repository drop-down list
Lists the repositories in the local database. This list includes the same projects that the repository you choose contains. It also lists any projects that you create locally.
Projects list
Type
Displays the type of each new or checked out project or object that the local repository contains. Projects or objects that you download through a Get are not available for checkin and Siebel Tools does not list them. You can check in only projects or objects that you previously checked out or that you created locally.
Name
Displays the name of the checked out object.
Status
Contains the value New or Locked for each project or object. This value indicates if you created it or obtained it through a checkout.
Lock/Creation Date
Displays the date and time for one of the following:
  • When you created the project or object
  • When you checked out the project or object from the Siebel Server
Language
Displays the language you used to check out the project or object.
Option buttons
Selected Objects
If this check box includes a check mark, then you can manually choose an individual project or object to check in.
Locked/New Objects
Chooses all of the projects or objects that the list contains. This list includes all the projects or objects you created or that you obtained through checkout.
Maintain Lock
Does not remove object locks on the Siebel Server or on the local database after checkin.
Buttons
Undo Check Out
Does not check in objects to the Siebel Server. This button releases the lock on the Siebel Server so that another developer can work on the objects. It does not unlock the locks on the local database.
Validate
Validates the projects you choose.
Check In
Starts the check-in process.
Diff
Opens the Project Differences dialog box. This dialog box allows you to compare the objects that you check in to the versions of these objects that reside on the Siebel Server. For more information, see Validating Objects.
Options
Opens the Developer Tools Options dialog box. This dialog box allows you to specify check-in and check-out settings. For more information, see Specifying the Data Source That Siebel Tools Uses.
Cancel
Closes the Check In dialog box.
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
