Using Siebel Tools > Checking Out and Checking In Projects and Objects > Using Checkout and Checkin >
Checking In Projects or Objects to the Server Repository
This topic describes how to check projects or objects into the server repository. This task is a step in Roadmap for Setting Up and Using Siebel Tools. To check in projects or objects to the server repository
- Make sure the EnableObjectCOCI parameter is set to TRUE.
For more information, see Step 1.
- Click the Tools menu, and then click Check In.
- In the Check In dialog box, make sure you choose the correct repository.
For more information, see Elements of the Check In Dialog Box.
- Click Options.
- In the Development Tools Options dialog box, make sure you set the Siebel Server and the client Data Sources correctly, and then click OK.
For more information, see Specifying the Data Source That Siebel Tools Uses.
- Do one of the following:
- To check in some projects or objects, click Selected Objects, and then choose the projects and objects that you want to check in.
- To check in all locked projects and objects, click Locked/New Objects.
- Click Check In.
If an object references the project, then Siebel Tools does the following work:
- Unlocks this object in the local repository. Removing this lock allows another developer to check out the object. Siebel Tools removes the lock for each object that references the project.
- Copies this object from the local repository to the server repository. Siebel Tools copies each object that references the project, including any new objects that you added.
