Using Siebel Tools > Checking Out and Checking In Projects and Objects > Using Checkout and Checkin >
Checking Out Projects from the Server Repository
This topic describes how to check out projects from the server repository. This task is a step in Roadmap for Setting Up and Using Siebel Tools. To check out projects from the server repository
- To enable object checkout, make sure the following parameter in the Siebel section of the tools.cfg file is set to TRUE:
EnableObjectCOCI=TRUE
If this parameter does not exist in the Siebel section, then add it now. For more information, see About the Configuration Files.
- Log in to Siebel Tools, connected to your local repository.
- Make sure the project allows object locking.
For more information, see Allowing Object Locking for a Project.
- Click the Tools menu, and then click Check Out.
- In the Project Check Out dialog box, make sure you choose the correct repository.
For more information, see Elements of the Project Check Out Dialog Box.
- Click the projects that you want to check out, and then click Options.
- In the Development Tools Options dialog box, make sure you specify the Server and Client data sources correctly, and then click OK.
For more information, see Specifying the Data Source That Siebel Tools Uses.
- In the Check Out dialog box, click Check Out.
Siebel Tools does the following:
- Locks all objects in the server repository that reference the project. This lock prevents another developer from checking out these objects.
- Copies all the objects that it locked. It copies these objects from the server repository to your local repository. These objects remain locked on your local repository. You can edit them.
