Table 40. Elements of the Project Check Out Dialog Box
Repository drop-down list |
Displays a list of repositories that the Siebel Server contains. The list of projects in the projects list displays the list of projects that reside in the server repository that you choose. If you choose a server repository that is different from the repository that is currently open in Siebel Tools, then Siebel Tools displays a warning, and you must Get all projects or choose another repository. |
Projects list |
Project |
Displays the name of each project that the server repository contains. |
Updated |
If the Siebel Server Locked By and Locked Date are different from the client version, then Siebel Tools displays a value of Yes. This value indicates that the local version of the project is not synchronized with the version that the Siebel Server contains. |
Server Locked By |
Displays the Logon Id of the developer who most recently checked out this project on the Siebel Server. |
Server Locked Date |
Displays the date of checkout. |
Client Locked By |
Displays the logon Id of the developer who most recently locked this project locally. |
Client Language |
Displays the language of the project that is currently locked in Siebel Tools. You can lock only one language at one time. |
Allow Object Locking |
If the project allows object checkin or checkout, then Siebel Tools displays a value of Yes. The default value is Yes. For more information, see Allowing Object Locking for a Project. |
Owner Branch |
Displays the owner branch for each project. If the project Owner Branch is not empty, then the Repository Branch that Siebel CRM assigns for this user must match. If these values do not match, then this user cannot check out the project or any objects that reference this project. Siebel Tools does not display this column in the Object List Editor, by default. To display it, you can do the following:
- In the Object Explorer, click Project.
- In the Projects list, right-click, and then click Columns Displayed.
- In the Columns Displayed dialog box, move the Owner Branch column to the Displayed Columns window, and then click OK.
Option buttons |
Selected projects |
Allows you to choose individual projects to check out or Get. |
All projects |
If this check box contains a check mark, then Siebel Tools chooses all projects in the repository to check out or Get. |
Updated projects |
If this option is active, then Siebel Tools chooses only projects that include an Updated value of Yes. This configuration allows you to check out or Get only those projects that reside on the Siebel Server that are new or are different from corresponding projects in the local repository. You typically do a Get to update your local repository. |
Get Locale Specific Data Only |
If this check box contains a check mark, then Siebel Tools gets only string translations and locale properties that Siebel CRM stores in the locale objects. It does not get data that Siebel CRM stores in the parent object of the locale object. |
Buttons |
Get |
Copies the projects that you choose to the local repository. It replaces any versions of these projects that already exist in the local repository but it does not lock these projects on the Siebel Server. You can Get any projects from the Siebel Server, including projects that someone else locked. For more information, see Allowing Object Locking for a Project. |
Check Out |
Copies all objects in the projects you choose to the local repository and locks them on the Siebel Server and in Siebel Tools. You cannot check out a project that is currently locked on the Siebel Server that someone else locked. |
Options |
Opens the Development Tools Options dialog box with the Check In/Out tab chosen. |
Cancel |
Cancels the checkout and closes the Check Out dialog box. |
