Table 41. Elements of the Object Check Out Dialog Box
Repository Text Box |
Displays the name of the current repository. |
Object List |
Type |
Displays the type of new objects or checked out objects that the local repository contains. Objects that you download through a Get are not available for checkin and Siebel Tools does not list them. You can check in only projects that you previously checked out or that you created locally. |
Name |
Displays the name of each object that Siebel Tools checks out. |
Updated |
If the Siebel Server Locked By and Locked Date are different from the client version, then Siebel Tools displays a value of Yes. This value indicates that your version of the project is not synchronized with the version that the Siebel Server contains. |
Object Locking |
If the project that this object references allows object checkin or checkout, then Siebel Tools displays a value of Yes. For more information, see Allowing Object Locking for a Project. |
Server Locked By |
Displays the logon Id of the developer who currently checked out this object on the Siebel Server. |
Server Language |
Displays the language you use when you check out the object on the Siebel Server. You can check out only one language at one time. |
Server Locked Date |
Displays the date of checkout. |
Client Locked By |
Displays the logon Id of the developer who currently locked this object locally. |
Client Language |
Displays the language of the object that is currently locked in Siebel Tools. You can lock only one language at one time. |
Project Locked By |
Displays the logon Id of the developer who most recently checked out the project that this object references. |
Get Locale Specific Data Only |
If this check box contains a check mark, then Siebel Tools gets only string translations and locale properties that Siebel CRM stores in the locale objects. It does not get data that Siebel CRM stores in the parent object of the locale object. |
Buttons |
Get |
Copies the objects that you choose to the local repository. It replaces any versions of these objects that already exist in the local repository but it does not lock these objects on the Siebel Server. You can Get any objects from the Siebel Server, including objects that someone else locked even if the Allow Object Locking field of the project that the object references contains a check mark. For more information, see Allowing Object Locking for a Project. |
Check Out |
Copies all objects that you choose to the local repository and locks them on the Siebel Server and in Siebel Tools. You cannot check out an object that is currently locked on the Siebel Server that someone else locked. |
Options |
Opens the Development Tools Options dialog box with the Check In/Out tab chosen. |
Cancel |
Cancels the checkout and closes the Object Check Out dialog box. |
