Using Siebel Tools > Checking Out and Checking In Projects and Objects > Using Checkout and Checkin >
Locking a Project in the Local Repository
You can lock a project in the local repository without checking it out from the server repository. This is useful in the following situations:
  • You want to test a configuration on your local computer, but you do not want to prevent other developers from checking out this project from the server repository.
  • You discard your work when you are done. In this situation, it is not necessary for you to check in an object that you modify.
If you lock a project in the local repository, then consider the following:
  • You cannot check in a project or object that is locked in the local repository.
  • To check a project into the server repository, you must first check out this project only from the server repository.
  • If you lock a project locally, and if you get or check out this project, then Siebel CRM overwrites this project and all objects that reference this project.
To lock a project in the local repository
  1. Log in to Siebel Tools, connected to the local repository.
  2. Do one of the following:
    • To lock a project from an object:
    • To lock a project from the Projects list:
      • In the Object Explorer, click Project.
      • In the Projects list, locate the project that you want to lock.
      • Make sure the Locked property contains a check mark.
        After you lock a project, you can edit all objects that reference this project.
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
