Using Siebel Tools > Checking Out and Checking In Projects and Objects > Setting Options for Checkout and Checkin >
Configuring Siebel Tools to Restart Editors After Checkout
If the Restart the Editors After Check Out check box includes a check mark, and if an editor is open when you do a checkout, then Siebel Tools restarts the editor after checkout finishes.
To configure Siebel Tools to restart editors after checkout
  1. In Siebel Tools, click the View menu, and then click Options.
  2. In the Development Tools Options dialog box, click the Check In/Out tab.
  3. Make sure the Select the Restart the Editors After Check Out check box includes a check mark.
  4. Click OK.
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
