Using Siebel Tools > Archiving Objects > Exporting Objects to an Archive > Using the Command Line to Export Objects to an ArchiveYou can use the command line to export objects to an archive. To use the command line to export an archive
Input File That Batch Export UsesThe batch export switch uses an input file that specifies the objects to export. This input file uses the following format. You cannot use a space before or after a comma in this file:
You can include multiple lines in the input file and each of these lines can specify to export multiple objects to a different SIF file. If you specify the same SIF export file in multiple lines, then batch export uses only the last export that you specify. For example, consider the following line from an input file. In this example, the batch export switch exports all business components where the Name property is like *Account* to a repository file named export.sif: |
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
