Using Siebel Tools > Checking Out and Checking In Projects and Objects > Using Checkout and Checkin >
Unlocking a Project
This topic describes how to unlock a project. To unlock a project
- Log in to Siebel Tools, connected to the local repository or the server repository, depending on where the locked project resides.
- In the Object Explorer, click Project.
- In the Projects list, locate the project that you want to unlock.
For more information, see Locating and Modifying Object Definitions in the Object List Editor.
- Make sure the Locked property does not contain a check mark.
Siebel Tools removes the lock from the project and all objects that reference this project. After you unlock a project, Siebel Tools makes all objects that reference the project available for editing. For more information, see Using the W Property.
