Using Siebel Tools > Checking Out and Checking In Projects and Objects > Using Checkout and Checkin > Undoing Project CheckoutAfter you check out a project, you can undo the checkout. You can also use the Get option to do the following:
For more information, see Getting Projects from the Server Repository.
Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
