Using Siebel Tools > Checking Out and Checking In Projects and Objects > Getting Projects from the Server Repository > Getting All Projects from the Server RepositoryA Full Get is a type of Get that copies all projects from the server repository to your local repository. It is useful the first time you initialize the local repository, or if you want to replace the projects that your local repository contains. You can use a Full Get to synchronize the local repository with modifications that reside in the server repository. You must do a Full Get before you compile the repository because the repository must use the full set of Siebel objects. For more information, see Compiling Your Modifications. This task is a step in Roadmap for Setting Up and Using Siebel Tools. To get all projects from the server repository
Configuring Siebel Tools to Do Database Commits at the End of a Full GetThis topic describes how to configure Siebel Tools so that it performs database commits only at the end of a Full Get. A Full Get performs database commits in regular intervals during the Get operation rather than during a single commit at the end of the Get, by default. A Full Get can provide better performance, but if an error occurs, then you must do the Full Get again. To configure Siebel Tools to do database commits at the end of the Get |
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
