Using Siebel Tools > Checking Out and Checking In Projects and Objects > Getting Projects from the Server Repository > Getting Locale Data from the Server RepositoryAfter you do a Full Get, you can get locale data without also getting parent objects. This configuration is useful if you work in one language, and then switch to another language. For example, you populate your local repository with English (ENU) data, but you want to switch to Japanese (JPN). After you switch the language mode to JPN, you can use the Get Locale-Specific Data option to copy only JPN records from the server repository to your local repository. To get only locale data for projects
Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
