Using Siebel Tools > Compiling, Testing, and Troubleshooting Your Customizations > Compiling Your Modifications >
Using an Incremental Repository Upgrade Kit
If you compile a repository to create an Incremental Repository Upgrade Kit, then you can specify a reference repository when you compile the new repository. This reference repository can minimize the size of the kit and the time required to do an upgrade. A reference repository is a prior version of the repository. The incremental repository upgrade includes only the differences between the reference repository and the new repository. For more information, see Siebel Anywhere Administration Guide. To use an incremental repository upgrade kit
- Click the Tools menu, and then click Compile Projects.
For more information about projects, see Checking Out and Checking In Projects and Objects.
- In the Object Compiler dialog box, click Reference SRF, and then specify the path and file name of the prior repository version.
- Click the projects you want to compile.
- Click Compile.
