Using Siebel Tools > Compiling, Testing, and Troubleshooting Your Customizations > Compiling Your Modifications > Compiling ObjectsYou can compile a single object or a group of top-level objects of the same type. For example, if you modify several applets, then you can compile only the applets you modify rather than compiling entire projects. For information about top-level object types, see Displaying Object Types in the Object Explorer.
Objects That Must Exist in the Production DatabaseTo work correctly, the following repository objects must exist in the production database. Siebel CRM sets the No Compile property for these objects to TRUE, by default. Siebel Tools does not compile them to the repository. You can configure these objects:
You cannot configure the following objects but they must exist in the production database. These objects allow you to use various administrative and batch features: |
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
