Using Siebel Tools > Compiling, Testing, and Troubleshooting Your Customizations > Testing and Troubleshooting Your ModificationsThis topic includes the following information: To test your modifications, you can use a local instance of the Siebel Web Client that runs on your computer. If you compile objects and test the results locally, then consider the following:
This task is a step in Roadmap for Setting Up and Using Siebel Tools. For more information about installing the Siebel Web Client, see the Siebel Installation Guide for the operating system you are using. For information about using debug windows, see the following information: |
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
