Using Siebel Tools > Using Siebel Script Editors > Using the Siebel Debugger > Using the Watch Window While it Monitors a ScriptThe Watch window displays variables and variable values. You can use it to monitor these values while a script or workflow process runs. The Watch window supports the following variable types:
For a detailed example that uses the Watch window, see the information about defining a workflow process that closes obsolete service requests in Siebel Business Process Framework: Workflow Guide. To use the Watch window while it monitors a script
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
