Using Siebel Tools > Using Siebel Script Editors > Using the Siebel Debugger >
Setting Debug Options
This topic describes how to set debug options. To set debug options
- In Siebel Tools, click the View menu, and then click Options.
- In the Development Tools Options dialog box, click the Debug tab, and then set the options.
The following table includes example settings for the Debug tab. For more information, see Development Options for Debugging.
Executable |
siebel.exe |
CFG File |
c:\siebel\bin\w32u\enu\uagent.cfg For more information, see Specifying the Data Source That Siebel Tools Uses. |
Working Directory |
c:\siebel\bin\w32u |
Arguments |
You can use the following arguments:
- /h.
- /l. Sets the language that Siebel Tools uses for the debug session.
You can include these arguments on the same line and in any order. For example, you can use one of the following for ENU:
User Name |
sadmin |
Password |
Data Source |
Sample |
Enable Profiler |
Contains a check mark. |
- Click the Scripting tab.
- In the Debugging section, set the options, and then click OK.
For more information, see Development Options for Visualization Views.
