Table 49. Development Options for Debugging
Executable |
Enter the name of the Siebel Web Client executable. For example: siebel.exe
The default value is siebel.exe. Siebel Tools runs this executable in debug mode or automatically after compile finishes. |
CFG File |
Enter the name of the configuration file that the Siebel client uses. For example: C:\Program Files\Siebel\8.0\web client\BIN\ENU\uagent.cfg
For more information, see Specifying the Data Source That Siebel Tools Uses. |
Browser |
Enter the path to the browser executable. For example: C:\Program Files\Internet Explorer\iexplore.exe
Working Directory |
Enter the Siebel root folder. This folder includes the Siebel executable and the DLLs (dynamic link libraries). For example: C:\Program Files\Siebel\8.0\web client\BIN
Arguments |
Enter the options that Siebel Tools uses when it opens the watch window:
- /h. Enables local debugging of Server scripts.
- /s file name. Enable SQL spooling.
Prompt for This Information Each Time |
If this check box contains a check mark, then Siebel Tools displays information each time it runs a debug operation. For example, it can display the name of the executable, the name of the CFG file, the browser configuration, and so on. |
Show Workflow Primary Business Component Data |
If this check box contains a check mark, then the Watch window in the Workflow Simulator displays information about the workflow process. It displays the name of each business component field and the value for each of these fields. These fields include fields from the primary business component of the business object that the workflow process references. |
User Name |
Enter the user name that Siebel CRM requires to log in to the Siebel application you are debugging. |
Password |
Enter the password that Siebel CRM requires to log in to the Siebel application you are debugging. |
Data Source |
Choose a default data source. The values you can choose depend on Oracle's Siebel Tools configuration file that you specify in the CFG File option. The Siebel Web Client connects to this local database. For more information, see Specifying the Data Source That Siebel Tools Uses. |
Enable Profiler |
For more information, see Using the Script Profiler. |
