Using Siebel Tools > Reference Materials for Siebel Tools > Dialog Boxes That Set Development Options >
Development Options for Scripting
Table 48 describes the development options that you can set for scripting. For more information, see Setting Options for the Siebel Script Editor.
Table 48. Development Options for Scripting
Section
Option
Description
Font
Name
Sets the font name that appears for a script.
Size
Sets the font size that appears for a script.
Script Assist
Allows you to set Script Assist options. You must enable the ST eScript Engine so that you can use Script Assist. For more information, see Overview of Using the ST eScript Engine.
Enable Method Listing
Allows Script Assist to display a drop-down list that includes the methods and properties that are available for a declared object.
Tab Width
Specifies the number of spaces that Siebel Tools uses for a tab character in the script. The default value is four spaces.
Enable Auto Complete
If this check box contains a check mark, then Siebel Tools auto completes a method name or property name. It does this if you enter the minimal number of unique characters that are required to complete the name.
If it locates strings that are not unique, then it displays a drop-down list.
Auto Indent
If this check box contains a check mark, then Siebel Tools indents each succeeding line of script to the position that the current line sets.
Enable Favorites
If this check box contains a check mark, then Siebel Tools displays the object, method, or property name that you use most frequently in italics at the top of the Script Assist window.
Engine Settings
For more information, see Setting Options for the ST eScript Engine.
Language
Default Language for New Scripts
You can choose eScript or Visual Basic.
Browser Script Compilation Folder
You can specify the folder where Siebel Tools stores the Browser script that it compiles. For example:
C:\Program Files\Siebel\8.0\web client\PUBLIC\enu
In this example, browser script files reside in the following folder:
C:\Program Files\Siebel\8.0\web client\PUBLIC\enu\genbscript_time stamped_folder\bscripts\all.
Debugging
Allows you to set options for the Siebel Debugger. For more information, see Setting Debug Options to Open the Siebel Client.
Adjust Breakpoint to Next Valid Line
If this check box contains a check mark, and if you delete a breakpoint on an invalid code line, then Siebel Tools creates a breakpoint at the next valid line.
Make Debugger Window Active When Debugging
If this check box contains a check mark, then Siebel Tools displays the Siebel Debugger window when it is in debug mode.
Always Enter the Debugger When an Error Occurs
If this check box contains a check mark, and if a script error occurs, then Siebel Tools displays the Siebel Debugger window.
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
