Using Siebel Tools > Reference Materials for Siebel Tools > Dialog Boxes That Set Development Options >
Development Options for Visualization Views
Table 47 describes the development options that you can set for visualization views. For information about using this dialog box, see Viewing Object Relationships.
Table 47. Development Options for Visualization Views
Option
Description
Use System Font
Uses a system font for the visualization views.
Use a Custom Font
You can use the Font, Size, and Zoom drop-down lists to choose your preferred font.
Boxes with 3D borders
Displays boxes with a three dimensional border.
Icon and name only
Displays the object name and the same object icon that the Object Explorer shows.
Simple outline boxes
Displays each object name in a simple box.
Always print outline style
Displays visualization details in outline style.
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
